It is currently Sat Aug 09, 2025 8:56 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Need a Pickup
PostPosted: Sun Apr 02, 2017 3:55 pm
First name: Danny
Last Name: Vincent
No one has mentioned sound hole mounted pups. I have one in one of mine. A Baggs. I don't plug in as often as I use to but I was pretty happy with the sound. I see some pretty heavy hitters using them.
PostPosted: Sun Apr 02, 2017 6:56 pm
Danny --- I have wondered the same thing ever since I started following this young man's career
Ken Cierp
PostPosted: Sun Apr 02, 2017 9:51 pm
First name: Garrett
Last Name: Colllier
DannyV wrote:
apostleguitarcompany wrote:
Would something like this be suitable to attach the JJB/ K&K?
https://www.amazon.com/Intertape-Polymer-Group-9970-1-88-Inches/dp/B000I1EHK0/ref=sr_1_8?ie=UTF8&qid=1491159035&sr=8-8&keywords=two+sided+thin+adhesive+tape
Seems like it would work, or maybe some other type of adhesive tape. Would tape really dampen the sound that much?
Likely a little on the heavy side Garret. I do have some very thin stuff I got from Lee Valley. The comments an using CA is making me ponder. It's what I have used in the past but I can see where it could become problematic.
Thanks for the answer Danny. I thought about the adhesive sheet that StewMac sells for pickguards, but, it states that it's for finished surfaces only. Maybe someone could put a little shellac or some other small amount of finish on the bridge plate? I could see where that might pose a slight challenge to do on a finished guitar. It would be easy enough to do on a new build that you planned on using the K&K/JJB on though.
I am very interested in the JJB but the possibility of it eventually breaking or me just wanting to try something else is there. So personally, I think I would rather use a more reversible method for attaching it.
PostPosted: Mon Apr 03, 2017 6:21 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I'm not sure how many have installed K&K Pure or JJB systems, but the K&K installation kit comes with film adhesive sheets for what the makers characterize as temporary installation...so no need to substitute other materials that might further degrade performance. K&K notes that about 40% of output is lost by using a film adhesive versus CA for installation, which is most definitely a problem for more heavily built instruments or those suffering from volume or projection losses due to other reasons, as the K&K works best when installed with CA on fairly responsive instruments. We recommend against using the passive K&K and JJB systems for instruments like the older US-made Guilds or those instruments overdue for a neck reset.
When we install the Pure, we shellac the bridge plate (as we also do for all 'peel and stick' adhesives inside the box, such as wiring hangers, battery bag Velcro pads, or preamp/volume units) with a couple coats of 1 pound mix shellac padded on to seal the wood and reduce glue penetration and porosity. While we have had no real issues cleanly removing glued K&K and JJB sensors, one or more of the disks may be damaged, so we carefully separate with a fresh razor blade, and hope for the best. If shellac is used to prep the bridge plate, we've found that separation and cleanup on the bridge plate is a little easier, and there is no noticeable impact on pickup performance. We inform customers that permanently installed K&K and JJB sensors are generally removable without damage to the instrument, but will likely not be reusable after removal...our priority is on avoiding damage to the instrument, so about 25% of removals see some damage to the brass disk or plastic cover. Even with pickup sensors that show no obvious damage and appear to function normally, we do not have the ability to detect hidden damage, so strongly recommend against reuse.
- Beth Brower
These users thanked the author Woodie G for the post: DannyV (Mon Apr 03, 2017 11:17 am)
PostPosted: Mon Apr 03, 2017 9:17 am
I like the element from Baggs. I've played in really aggressive bands at church and secular gigs as well and the element equipped guitars were the only ones that wouldn't squeal and growl like an angry wild boar. The simple, two dial volume and tone sound hole control is easy to get to but clean and out of sight. Even more appealing is the MiSi version that requires no 9 volt battery inside the guitar. It has a rechargeable nicad disc battery mounted at the end pin or volume controls and it recharges with an included wall wart charger that plugs into the 1/4 end pin jack. I think since you mentioned that your friend will likely only plug-in twice a year, this would be a great option for him and would avoid the potential dead battery leaking inside the instrument.
jw ( o)===:::
These users thanked the author joe white for the post: DannyV (Mon Apr 03, 2017 11:16 am)
PostPosted: Mon Apr 03, 2017 9:25 am
I should have mentioned that you can get other pickups with the MiSi (my sigh)system, it's not limited to the element under saddle one.
http://mi-si.com
jw ( o)===:::
PostPosted: Mon Apr 03, 2017 11:14 am
First name: Danny
Last Name: Vincent
Well that makes sense. A sharp razor blade and a careful hand should make short work of removing the transducers . The only reason this would be removed, in this case, would be PU failure in which case damage to the unit is not an issue.
Just curious if you've had any experience with the active JJB? That's what I ordered but the control (sound hole mounted) looks to be by no means Baggs quality. In fact looked a little cheesy. I'll let you know when I get it in my hands.
Thanks you all. I know this topic has been discussed at least once a year but it is a good topic. [:Y:]
PostPosted: Mon Apr 03, 2017 11:32 am
First name: Garrett
Last Name: Colllier
Danny,
I look forward to reading your feedback and opinion on the JJB. That's the same one I think I'm going to try as well.
Woodie,
Thank you very much for your helpful insight into the removal of the pickups. It's comforting to know that you can remove them without damage to the guitar itself.
cron
